TwinTurbo.NET: Nissan 300ZX forum - Re: You've gotten this far, why not remove the fuel rail
Subject Re: You've gotten this far, why not remove the fuel rail
Posted by maur010 on May 01, 2017 at 6:15 AM
  This message has been viewed 479 times.
In Reply To You've gotten this far, why not remove the fuel rail posted by itsa300zx on April 28, 2017 at 12:08 PM
Message Thanks guys. I was able to get them up with a regular ratchet. I used bit that was slightly smaller then the head of the screw, tapped down several times enough to make a slight indent in the screw. Then went to the next size up which went over the screw head and all 4 of them came up.
I've been told that the stock fuel rails perform just as well as the performance rails, so why the need to switch out the rails?
