TwinTurbo.NET: Nissan 300ZX forum - If stuck I Tap with hammer on a drift pin, then I use >>
Subject If stuck I Tap with hammer on a drift pin, then I use >>
Posted by ZUL8TR on April 28, 2017 at 4:31 AM
  This message has been viewed 523 times.
In Reply To Injector Phillips Heads Stripped posted by maur010 on April 27, 2017 at 11:56 PM
Message medium size vise grip pliers in a vertical mode if minimal room, horizontal better if room cause the teeth of the vise grip are useable. Vise grip should have a real tight adjustment to grip the head of the Phillips. Use more PB and a couple more taps with the drift pin to shock the threads. The impact driver is ok if there is enough Phillips slots left to effectively use?
ZUL8TR
