TwinTurbo.NET: Nissan 300ZX forum - Sorry, made that sound over complicated.
Subject Sorry, made that sound over complicated.
Posted by TyTyIsFly27 on April 23, 2017 at 3:33 PM
  This message has been viewed 547 times.
In Reply To You are hooking BOTH wires on the boostsolenoid to posted by kickerzx on April 23, 2017 at 03:18 AM
Message I have the sub-harness for the ECU and IO box. DPO1 from the ECU itself just has two wires, purple and black, which I connected to either side of the solenoid. I assumed that one of these was a power, and one would be a ground. Not sure how else it would work. Is there a separate power wire that needs to be connected to the ECU to give power to accessories like this?
I have also tried to feed the solenoid straight from the battery, just to test and it still doesn't click when I charge the MAP sensor up to pressure. I have tested both of my solenoids though, and both are operational outside of the system.
I am thinking something on the ECU harness itself must be wired wrong, but I am not throwing codes.
