TwinTurbo.NET: Nissan 300ZX forum - Re: Block water jacket ports
Subject Re: Block water jacket ports
Posted by 1308cats on April 20, 2017 at 4:28 PM
  This message has been viewed 512 times.
In Reply To Block water jacket ports posted by 1308cats on April 16, 2017 at 07:41 PM
Message The only reason I mentioned leaving out the thermostat is that some racers who leave out the thermostat will replace them with a washer with a smaller hole in order to slow the flow of the coolant to allow it to cool better. I don't plan to leave out the thermostat. I was asking if maybe the holes in the gasket were smaller than the ports in the block in order to slow the flow of the coolant. Since these ports feed coolant into the heads, maybe they wanted to keep more heat in the heads? Something like they circulated coolant through the base of the throttle bodies to help with emissions? Like I said, Tomei and Cometic use much larger holes at upper and middle locations so it must not be hyper critical. I've read AshZ and MotoIQ articles about cleaning up the central water passage and intend to do this after I finish cleaning the water jacket with vinegar and pop out the freeze plugs.
