TwinTurbo.NET: Nissan 300ZX forum - Those low numbers are not a good sign but I would not >>
Subject Those low numbers are not a good sign but I would not >>
Posted by ZUL8TR on April 20, 2017 at 4:01 AM
  This message has been viewed 431 times.
In Reply To Re: Blue smoke posted by Anath3ma on April 18, 2017 at 05:34 PM
Message assume the worst yet. Check the other 2 and see what they are. You might have some rings that need to be freed up with a cleaner added to the oil run engine per directions then change oil and filter. I recall buying a car long ago that wasn't in the greatest shape in engine dept. Did a flush and changed oil and filter several times in a few thousand miles and it improved. If you do the oil changes just use a name brand 10w 30 oil no synthetics.
Keep in mind at 211k miles no miracles are expected this is a high mileage car you bought and it probably didn't receive the best of care.
ZUL8TR
