TwinTurbo.NET: Nissan 300ZX forum - You can do a power balance test to isolate which
SammybTT(TN)
on April 19, 2017 at 12:08 PM
Check engine light stays on.
posted by Justamerefox
on April 15, 2017 at 01:18 PM
cylinder is the weak performer. There are detailed descriptions on this procedure. Use the search function for power balance test and you will be golden. Good luck
Justamerefox
13:18:16 04/15/17
I'd pull the trouble codes causing the check light to come
jzack
15:23:35 04/15/17
Re: I'd pull the trouble codes causing the check light to come
Justamerefox
18:15:29 04/17/17
You can do a power balance test to isolate which -
SammybTT(TN)
12:08:47 04/19/17
