TwinTurbo.NET: Nissan 300ZX forum - CAS spinning freely with ignition on and fuel pump
Subject CAS spinning freely with ignition on and fuel pump
Posted by jzack on April 12, 2017 at 8:30 AM
  This message has been viewed 412 times.
In Reply To cranks but no start posted by aztec300z on April 12, 2017 at 12:16 AM
Message disabled should allow you to hear the injectors clicking. Use a length of hose or an automotive stethoscope to hear an individual injector. Best to actually touch the top of the injector. Pick an easier to reach one towards the front of the engine. Another way to hear them is using a long screwdriver or metal rod as a sound conductor (to your ear) but I find that method more cumbersome.
The CAS also controls the spark plug coil packs. Pulling one of them and using a grounded spare plug - any type will do, to see spark, is another way to test the CAS. Same as above, ignition on and fuel pump disabled is best for a no engine running test.
