TwinTurbo.NET: Nissan 300ZX forum - Tps question
Tps question
Bigmatthew86
on April 09, 2017 at 9:53 AM
I believe I already know the answer but just thought I'd make sure. I have my tps adjusted to .42 closed but at wide open it only reads 3.86. That is the best I can dial it in. I assume it means time for a new sensor. Car is a tt/auto.
Tps question -
Bigmatthew86
09:53:17 04/09/17
The sensor is fine. (n/m)
MixManMash
10:01:32 04/09/17
Re: The sensor is fine.
Bigmatthew86
10:33:31 04/09/17
You thought wrong. Factory service manual says
MixManMash
10:39:22 04/09/17
Re: You thought wrong. Factory service manual says
Bigmatthew86
10:41:37 04/09/17
Actually it should really read the same wether the engine is
kickerzx
11:12:23 04/09/17
Yep, you are correct. Clearly I had a brain fart
MixManMash
18:58:05 04/09/17
