TwinTurbo.NET: Nissan 300ZX forum - Re: 1990 300zx NA Heater Mode Door
Subject Re: 1990 300zx NA Heater Mode Door
Posted by cygate on April 03, 2017 at 9:28 PM
  This message has been viewed 450 times.
In Reply To 1990 300zx NA Heater Mode Door posted by wbjrace on April 02, 2017 at 03:33 PM
Message As I posted before, you do not have e to pull the dash to change the mode door actuator, I know this because I've done it before. Remove the lower panel and the ac ducts on the drivers side under the steering column and you should be able to get to it. You only need to pull the dash if you need to change the air mix door actuator or the heater core. I'm very familiar with the the entire system on my 1991 NA.
