TwinTurbo.NET: Nissan 300ZX forum - One option to avoid pulling the dash is to manually set the
jzack
on April 03, 2017 at 8:02 AM
Re: 1990 300zx NA Heater Mode Door
posted by cygate
on April 02, 2017 at 09:30 PM
door to a generally acceptable position (i.e., upper and lower vent flow) and live with it that way.
wbjrace
15:33:18 04/02/17
cygate
21:30:24 04/02/17
One option to avoid pulling the dash is to manually set the -
jzack
08:02:23 04/03/17
Re: One option to avoid pulling the dash is to manually set the
wbjrace
11:13:25 04/03/17
Re: Re: 1990 300zx NA Heater Mode Door
wbjrace
11:19:41 04/03/17
i would pull the dash. that way you can check the
slayer fan
10:25:49 04/03/17
Re: i would pull the dash. that way you can check the
wbjrace
11:15:30 04/03/17
You have to undo the handful of bolts that hold the column
-Grimm-
15:03:10 04/03/17
cygate
21:28:27 04/03/17
