TwinTurbo.NET: Nissan 300ZX forum - I took ds wastegate arm off and back on drivers side to chec
Subject I took ds wastegate arm off and back on drivers side to chec
Posted by Smokiedabear on March 29, 2017 at 9:11 AM
  This message has been viewed 389 times.
In Reply To If it's running that rich, it's more than likely one of the posted by MixManMash on March 28, 2017 at 01:16 PM
Message k the actuator arm was fully closed, it looked like it was not, but it was.
When I took it off I knew it'd be fun getting it back on. It took about 20 minutes of getting creating with a small set of vice grips but it worked!
Needle nose vice grips might be great for the passenger side to pull the arm back.
I will take a look at the passenger side tonight, thank you for the recommendations!!
I keep having dreams that one of my turbo's is bad. I would accept this as being a possible problem but it would be pretty upsetting because I spent time rebuilding the turbo's the right way, balancing and all on new exhaust shafts/impellers.
