TwinTurbo.NET: Nissan 300ZX forum - Re: Rough idle solved by turning PRVR on during idle
Subject Re: Rough idle solved by turning PRVR on during idle
Posted by Metacom on March 25, 2017 at 10:42 AM
  This message has been viewed 436 times.
In Reply To Rough idle solved by turning PRVR on during idle posted by Metacom on March 24, 2017 at 07:19 PM
Message Went back and confirmed fuel pressure is good.
By passing the PRVR just returns to the rough idle. Pulling the vac hose off the side of the plenum and then capping that port results in the same smoother idle at 45 psi fuel pressure.
I've gone over all my vac lines many times and they've all been replaced still somehow the engine idles like it has a vacuum leak?
I also noticed I am getting positive pressure released from the gas cap instead of a vacuum? Gas cap is OE.
