TwinTurbo.NET: Nissan 300ZX forum - No, good luck compressing the tensioner with that.
itsa300zx
on March 20, 2017 at 3:51 PM
?? I said vise grip which is the correct namefor the tool ??
posted by ZUL8TR
on March 20, 2017 at 03:30 PM
use a m6x1.0mm bolt and turn it 1/16-1/8 of a turn at a time and allow few seconds for it to compress and repeat.
OR, as Smokie said remove from engine and compress with a bench vise and reinstall.
Hope that is clear:)
Timing Belt replace
ZUL8TR
04:08:07 03/20/17
yes, should be fine
Smokiedabear
09:19:58 03/20/17
It's impossible to have it 180 degrees out.
MixManMash
16:45:09 03/21/17
My question was not for R&R of the gears just the >>
ZUL8TR
05:09:51 03/22/17
I was responding to Smokiedabear. Even on a new engine,
MixManMash
17:14:52 03/22/17
With all 5 timing marks lined up, you are at comp stroke
itsa300zx
10:48:06 03/20/17
Yes that seems correct since camshafts rotate >>
ZUL8TR
11:30:48 03/20/17
Vice, not vice grips to compress tensioner if needed. (n/m)
Smokiedabear
14:48:10 03/20/17
ZUL8TR
15:30:47 03/20/17
No, good luck compressing the tensioner with that. -
itsa300zx
15:51:49 03/20/17
And new tensioners come compressed anyways. (n/m)
itsa300zx
15:54:46 03/20/17
It's clear, Thanks (n/m)
ZUL8TR
03:22:36 03/21/17
To add, if you are ever compressing the old tensioner,
MixManMash
16:48:05 03/21/17
How do you tell whan the new TB was made >>>
ZUL8TR
08:40:31 03/21/17
