TwinTurbo.NET: Nissan 300ZX forum - I would keep the same brand and design on the F and R>>
Subject I would keep the same brand and design on the F and R>>
Posted by ZUL8TR on March 20, 2017 at 3:50 AM
  This message has been viewed 365 times.
In Reply To Mixing tires- P Zero System front P Zero Rosso rear? posted by madkiwi on March 18, 2017 at 11:29 AM
Message You do not know the operation characteristics of each on Your car. If straight line running no issue but for daily use I say get all the same brand and tread design and speed and temp rating.
Between you and the road that small patch of tire is all you have.
A speed rating on the tire is like max not to exceed pressure on the tire wall. Reference only you proceed at your own risk. Not all tires off the assembly line are speed tested. There are a lot more parts on the car that need to be in great shape for excessive speed running. Make sure your rims are straight and true and in spec for radial and lateral runout.
ZUL8TR
