TwinTurbo.NET: Nissan 300ZX forum - Did you swap the fuel temp sensor or the coolant temp sensor
MixManMash
on March 17, 2017 at 7:57 AM
Re: Code 42 is for the fuel temperature sensor. But IIRC, that
posted by aztec300z
on March 16, 2017 at 10:20 PM
I would check wiring between the fuel temp sensor connector and the ECU.
Can you hear the fuel pump run?
code 42
aztec300z
21:38:20 03/16/17
MixManMash
21:42:48 03/16/17
aztec300z
22:20:46 03/16/17
Did you swap the fuel temp sensor or the coolant temp sensor -
MixManMash
07:57:40 03/17/17
Re: Did you swap the fuel temp sensor or the coolant temp sensor
aztec300z
20:03:34 03/21/17
Basics...what happens when you turn the key?
white22sky
18:14:57 03/17/17
Code 42 will not keep it from starting. While you were...
DVDBURN (MD)
18:43:38 03/18/17
