TwinTurbo.NET: Nissan 300ZX forum - Note - the upgraded PTU is installed using an adapter
Subject Note - the upgraded PTU is installed using an adapter
Posted by jzack on March 12, 2017 at 10:42 AM
  This message has been viewed 445 times.
In Reply To Re: Check continuity between the signal wire and the PTU posted by Mglide86 on March 12, 2017 at 09:19 AM
Message harness to go from the old style connector to new. A number of folks have had issues with that harness due to corrosion. This would be a good thing to check, pull the connectors apart for a visual look-see. Try wiggling the adapter harness while the car is running and see if anything changes? Just be careful since the harness is close to the fan.
