TwinTurbo.NET: Nissan 300ZX forum - Check continuity between the signal wire and the PTU
Subject Check continuity between the signal wire and the PTU
Posted by MixManMash on March 11, 2017 at 8:11 PM
  This message has been viewed 557 times.
In Reply To Re: Check the connectors for corrosion on the coil pack posted by Mglide86 on March 11, 2017 at 02:11 PM
Message connector. If that is good, check continuity between the PTU and ECU connector for cylinder #1. If that is good, I would guess that maybe your PTU has gone bad (especially if it is the pre-recall type).
