TwinTurbo.NET: Nissan 300ZX forum - Check the connectors for corrosion on the coil pack
Subject Check the connectors for corrosion on the coil pack
Posted by MixManMash on March 11, 2017 at 1:09 PM
  This message has been viewed 444 times.
In Reply To No spark cylinder #1 posted by Mglide86 on March 11, 2017 at 10:37 AM
Message connector and on the PTU for starters. After that, you should take a multimeter and check continuity between the coil pack connector and PTU connector, and the PTU connector and ECU connector.
Also, have you tried swapping coil packs to check if it's a failed coil pack?
