TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Front Differential Bushings - Reuse OEM Rubber Washer or no?
Subject Re: Re: Re: Re: Front Differential Bushings - Reuse OEM Rubber Washer or no?
Posted by ThisIsSparTTa on March 06, 2017 at 4:36 PM
  This message has been viewed 281 times.
In Reply To Re: Re: Re: Front Differential Bushings - Reuse OEM Rubber Washer or no? posted by nissubaru on March 06, 2017 at 04:19 PM
Message Not sure about the different diameters, I'm going to guess just a mistake , or that the diameter of the rubber was larger than the diameter of the washer to maybe better accommodate the rubber bushing below it.
IIRC mine is: Chassis>OE Cup washer with the "cup" facing down>all the poly bits>nut.
Looking closer at the 2 images now, I do see they want you removing the rubber from the cup washer btw.
