TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Regrinding can remove the nitrided hardened layer, which is
Subject Re: Re: Re: Regrinding can remove the nitrided hardened layer, which is
Posted by itsa300zx on March 01, 2017 at 11:13 AM
  This message has been viewed 375 times.
In Reply To Re: Re: Regrinding can remove the nitrided hardened layer, which is posted by Tech@EPR on February 28, 2017 at 11:14 PM
Message Upto 3mm(0.118")?? Are you sure about that. I need to find a VG crank and cut one up for case depth hardness survey.
In the 20 years of materials testing and doing case depths daily, I have never encountered a nitrided steel component having a case of >0.020" deep (measured to a industry std of 50HRC). In any case that was >0.020" the nitrided case always showed signs of cracking/ spalding. However, if the VG crank was carbo-nitrided, (ie carburized then nitrided); I can see the case being upto 3mm deep.
Does any one have facts of how the VG crank was hardened? I guess we will find out once I source a crank for some destructive testing.
IMHO, I would hardness check the journal before assembly, but thats just me:)
