TwinTurbo.NET: Nissan 300ZX forum - clean corrosion and use dielectric grease at all connectors>
Subject clean corrosion and use dielectric grease at all connectors>
Posted by ZUL8TR on February 24, 2017 at 4:42 PM
  This message has been viewed 364 times.
In Reply To Not-so-Newb Here, Second Z32 New Problem Dreaded Hesitation posted by ezhilerated on February 24, 2017 at 02:40 PM
Message and battery posts and clamps, clean grounds and use the grease. I do this to all cars I own for PM. I also added a ground net system to the Z for additional grounds. Some repeat here from what you did - Check settings on the TPS, clean AIV system, clean the throttle bodies, synchronize the throttles, air cleaner?, check engine vacuum and look for leaks, clean the MAF sensor with correct chemical strictly for that, check thermostat operation for correct open and operational temp.
[ http://www.atlanticz.ca/zclub/techtips/vacuum/ ]
Very steady needle at a given rpm is important.
ZUL8TR
