TwinTurbo.NET: Nissan 300ZX forum - When pushing the FUCA out with a shim or if
Subject When pushing the FUCA out with a shim or if
Posted by JMartz on February 23, 2017 at 2:08 PM
  This message has been viewed 354 times.
In Reply To Suspension overhaul posted by Anath3ma on February 23, 2017 at 12:48 AM
Message adjustable, because it is at 45 degrees to the FLCA, the movement is 70% out (positive camber) and 30% front (sine of 45). To correct the change in caster (if that interest you), adjustment via the FLCA will be necessary. Camber will be corrected at the expense of the location of the tire. If you are running wider, bigger tires, expect rubbing on the fender liner front at full lock.
