TwinTurbo.NET: Nissan 300ZX forum - That plug is brass and it has coolant behind it.
Subject That plug is brass and it has coolant behind it.
Posted by LitlElvis on February 18, 2017 at 10:36 AM
  This message has been viewed 351 times.
In Reply To Removing then oil block plug. posted by 0zcarsx on February 16, 2017 at 07:13 PM
Message The only way to remove it is to drill and tap then use a slide hammer to remove (obviously the engine would need to be out of the car to do this).
Also, it cannot be driven in farther, it is in a blind hole with only a small pocket exposed to the water jacket.
Small coolant leaks like this can typically sealed with Bar's Leaks added to the coolant, but personally I would just clean the plug with brake cleaner, let it dry, wipe some silicone into the pocket, let that dry, and it should stop the weeping.
