TwinTurbo.NET: Nissan 300ZX forum - The differential is mounted to the subframe or
Subject The differential is mounted to the subframe or
Posted by JMartz on February 17, 2017 at 6:36 AM
  This message has been viewed 222 times.
In Reply To Re: When I let off the throttle and push the pedal posted by nissubaru on February 16, 2017 at 09:13 PM
Message carrier. The rear suspension is also mounted to the subframe. The subframe is attached to the body at several points that are rubber. That whole assemble can do a little dancing, especially as the rubber mounts wear and weaken with age. The whole assembly connects to the motor/trans cluster via the two piece drive shaft. Movement on the subframe cannot be transferred to the engine/trans because the spline shafts slip in the longitudinal direction.
So my guess is that shift column movement during on/off throttle, is likely a result of softening of the 3 motor/trans attachment rubber mounting points.
