TwinTurbo.NET: Nissan 300ZX forum - Wiseco wrist pins fitment on stock rods
Subject Wiseco wrist pins fitment on stock rods
Posted by Kvert on February 12, 2017 at 2:56 PM
  This message has been viewed 256 times.
Message I've installed my wiseco Pistons on stock rods and they are very tight. 4 of them will still slide side to side on the pins, but grab the pin when you try to rotate it. The other two rods do not move on the pin, but will slide side to side with a little tapping. The stock setup had a floating rod and press fit on the piston pins. Now I have the opposite it seems since the wisecos have floating Pistons on the pins. Will this be ok to run or do I need to clearance the rod bushings so the rods float on the pins as well?
