TwinTurbo.NET: Nissan 300ZX forum - BTW, it won't start with the base map on it as it is set to
Subject BTW, it won't start with the base map on it as it is set to
Posted by MixManMash on February 04, 2017 at 10:27 AM
  This message has been viewed 272 times.
In Reply To You are connecting to it with the USB port directly on Halte posted by MixManMash on February 04, 2017 at 10:23 AM
Message mimic a relatively stock Z32 with MAFs.
Once you can communicate to it, you'll have to setup all your I/O and then load a base map that should be good enough to start / drive on until you get it tuned.
