TwinTurbo.NET: Nissan 300ZX forum - Haltech not turning on...
Subject Haltech not turning on...
Posted by Stanky on February 03, 2017 at 8:24 PM
  This message has been viewed 328 times.
Message as the title says, I installed the Haltech plug and play ECU, and wired in the MAP/IAT/widebands/e85 content sensor/boost solenoids to the ECU. I also installed injectors so the plenum came off. I checked the 3 grounds at the rear of the plenum and confirmed they are attached. Haltech has a blue light that should be lit when ignition is on, however I have nothing(hence the reason why it's not communicating with the laptop). Things I have checked....
- All fuses- GOOD
- Car DOES crank
- All interior lights/gauges/stereo work
Back probed the following at the ECU:
- ECU power supply pin 59 w/IGN ON- GOOD
- Injector power supply pin 109 w/IGN ON- GOOD
- Ignition signal Pin 45 w/IGN on- GOOD
anyone have any ideas? I hear the laptop make a noise when I plug the cable into the ecu, so i know the connection to the laptop is fine, The ECU just isn't turning on for some reason.
