TwinTurbo.NET: Nissan 300ZX forum - U dont need plenum on.
Subject U dont need plenum on.
Posted by ZXoltan on January 31, 2017 at 6:27 PM
  This message has been viewed 343 times.
In Reply To Re: Do you know for sure that the plug is firing? posted by Mglide86 on January 30, 2017 at 09:39 PM
Message just take coilpack with plug inserted into the end and put connectors for that cylinder on coil. Make sure plug threads are grounded (dont let tip touch anything) and crank engine. You should see sparks at the tip while cranking. Otherwise you have a bad coil, CAS, or wiring.
