TwinTurbo.NET: Nissan 300ZX forum - FWIW, that tube is the power steering cooler.
boileralum
on January 25, 2017 at 11:50 AM
PS return hose LH, runs from the rack to a steel tube
posted by itsa300zx
on January 19, 2017 at 01:42 PM
I had same hose fail, tried replacing with a shorter run of hose, and then overheated the PS during an autocross, making a mess. Ended up adding an aftermarket cooler which then fixed the issue.
What power steering hose is this? Leaking
nissubaru
19:59:27 01/18/17
rack and pinion? (n/m)
L£AÐZX
01:48:13 01/19/17
Re: rack and pinion?
nissubaru
11:15:13 01/19/17
High pressure hose from the rack to the pump. (n/m)
Woody75 (Denver)
12:39:32 01/19/17
Re: High pressure hose from the rack to the pump.
nissubaru
15:46:13 01/19/17
That would be my guess also
-Grimm-
16:03:53 01/19/17
itsa300zx
13:42:34 01/19/17
another link here
itsa300zx
13:47:03 01/19/17
Did Z1 ever fix the sweating issue with these?
WhiTTe Z
15:39:25 01/20/17
Re: PS return hose LH, runs from the rack to a steel tube
nissubaru
14:31:17 01/19/17
FWIW, that tube is the power steering cooler. -
boileralum
11:50:37 01/25/17
I thought only Euro models had PS coolers. (n/m)
itsa300zx
12:02:05 01/25/17
That single tube going across the crossmember is located
boileralum
10:37:55 01/30/17
Ahh, I see. never thought of it as a cooler:) (n/m)
itsa300zx
10:47:34 01/31/17
