TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Fuel pump noise goes away with low fuel?
Subject Re: Re: Fuel pump noise goes away with low fuel?
Posted by Smokiedabear on January 16, 2017 at 11:05 AM
  This message has been viewed 312 times.
In Reply To Re: Fuel pump noise goes away with low fuel? posted by Bigmatthew86 on January 13, 2017 at 11:02 PM
Message why not run a tt fpcu?
It will make your pump last longer and no crazy whine.
i did this and wired it to work right off I think it was 35 pin connecter from ecu to the fpcu, You can wire it into the drivers side footwell where the connect for the tt fpcu is.
It was kind of a pain getting wire from ecu behind dash (clothes hanger trick worked) and putting to footwell.
After this was done and tested for continuity it worked great.
Really happy I did it.
Berni gave me some of this advice along with old threads.
