TwinTurbo.NET: Nissan 300ZX forum - Re: '91 300zx stalling out over 60mph
Master_Blaster
on January 01, 2017 at 5:44 PM
posted by dmillz
on December 26, 2016 at 08:21 PM
I had this issue. Putting a front splash shield in helped out a little. But I narrowed mine down to a failing MAF.
dmillz
20:21:04 12/26/16
Metacom
22:57:44 12/26/16
Do you have a pop charger installed?
FrozTTy
08:12:36 12/27/16
This. More info:
MixManMash
08:42:06 12/27/16
I've had this problem but with the stock air box. When I
YlwPrlZTT
14:46:30 12/27/16
Weak fuel pump, insufficient fuel pressure in rail? (n/m)
JMartz
07:09:07 12/28/16
That wouldn't make sense when decelerating. (n/m)
MixManMash
08:03:05 12/31/16
Air leak then? (n/m)
JMartz
10:36:01 12/31/16
Doubtful. More like a MAF signal getting messed up by
MixManMash
16:55:14 12/31/16
Should an error code be issued by the OBD1 ECU
JMartz
11:11:33 01/01/17
No. Because the MAF isn't malfunctioning. The MAF is
MixManMash
17:32:36 01/01/17
Check your brake booster hoses for cracks or
doug8867
07:47:13 12/28/16
Re: '91 300zx stalling out over 60mph -
Master_Blaster
17:44:56 01/01/17
