TwinTurbo.NET: Nissan 300ZX forum - No. Because the MAF isn't malfunctioning. The MAF is
MixManMash
on January 01, 2017 at 5:32 PM
Should an error code be issued by the OBD1 ECU
posted by JMartz
on January 01, 2017 at 11:11 AM
seeing a weird flow pattern and because of that the ECU is altering timing / fuel delivery causing the engine to stall. The source problem is improper installation / placement of the pop charger.
'91 300zx stalling out over 60mph
dmillz
20:21:04 12/26/16
Re: '91 300zx stalling out over 60mph
Metacom
22:57:44 12/26/16
Do you have a pop charger installed?
FrozTTy
08:12:36 12/27/16
This. More info:
MixManMash
08:42:06 12/27/16
I've had this problem but with the stock air box. When I
YlwPrlZTT
14:46:30 12/27/16
Weak fuel pump, insufficient fuel pressure in rail? (n/m)
JMartz
07:09:07 12/28/16
That wouldn't make sense when decelerating. (n/m)
MixManMash
08:03:05 12/31/16
Air leak then? (n/m)
JMartz
10:36:01 12/31/16
Doubtful. More like a MAF signal getting messed up by
MixManMash
16:55:14 12/31/16
JMartz
11:11:33 01/01/17
No. Because the MAF isn't malfunctioning. The MAF is -
MixManMash
17:32:36 01/01/17
Check your brake booster hoses for cracks or
doug8867
07:47:13 12/28/16
Master_Blaster
17:44:56 01/01/17
