TwinTurbo.NET: Nissan 300ZX forum - engine rebuild
Subject engine rebuild
Posted by vracer1 on December 19, 2016 at 5:03 PM
  This message has been viewed 383 times.
Message I am rebuilding my 91 TT engine, it had about 122,000 miles on it. All parts will remain stock, pistons, cams, etc.unless it's better to go after market. This is the first time rebuilding one one these engines although I have build other engines. I have access to good machine work. My question is what if any parts should be replaced, i.e.pistons, valves, valve springs, etc. The engine was running fine no problems. The reason I am rebuilding is the injectors needed replacing so I got new injectors and purchased bigger turbos and all the breather mods and said why not...Thanks for the help.
