TwinTurbo.NET: Nissan 300ZX forum - I should have said, you can use a prybar into the
not4resaleZ
on December 14, 2016 at 4:53 PM
You should need to use your same bar on the crankshaft
posted by not4resaleZ
on December 13, 2016 at 03:20 PM
tooth of the flexplate and against the opening for the starter if you don't want to use the crankshaft bolt to stop the rotation when installing the flexplate to torque converter.
How much torque is required to turn over a Twin turbo
SammybTT(TN)
16:46:17 12/12/16
Re: How much torque is required to turn over a Twin turbo
GCamp
00:01:06 12/13/16
the torque converter will rotate but does to be difficult
SammybTT(TN)
20:46:21 12/13/16
not4resaleZ
15:20:05 12/13/16
thanks for the reply.
SammybTT(TN)
20:57:55 12/13/16
I should have said, you can use a prybar into the -
not4resaleZ
16:53:26 12/14/16
thats a great ideal. After I fabricate my shifter bracket
SammybTT(TN)
22:18:13 12/15/16
