TwinTurbo.NET: Nissan 300ZX forum - try a reset on the TPS. Turn key to on position then>>
Subject try a reset on the TPS. Turn key to on position then>>
Posted by ZUL8TR on December 13, 2016 at 3:42 AM
  This message has been viewed 292 times.
In Reply To RPM dip on cold start posted by Metacom on December 12, 2016 at 08:49 PM
Message unplug the gray connector in the harness for and near the TPS for about 5 sec then replug. Turn off key then start. If at any time when engine running the rpm does weird things a reset will usually fix it till the next time. Not sure what it will take to permanently fix these erratic idle issues after all items checked and appear in spec?
I have had good luck with reducing electric issues by cleaning the connectors and fill with dielectric grease and replug. Do same with battery + - connections. Also good engine grounds important and adding a ground net system (see Tech how to) for additional ground points.
ZUL8TR in Orlando,FL
