TwinTurbo.NET: Nissan 300ZX forum - This likely won't show up with a code. Sounds like a basic
Subject This likely won't show up with a code. Sounds like a basic
Posted by jzack on December 02, 2016 at 8:42 AM
  This message has been viewed 398 times.
In Reply To ignition problem posted by aztec300z on December 02, 2016 at 05:40 AM
Message electrical issue. Have you checked the fusible links? Small black box in front of battery. That's the cars primary electrical choke point on power distribution. Next up would be the fuses in both the engine bay and cabin fuse blocks.
I'm assuming your battery is good, battery post connections clean and solid too.
Did this issue just start happening or was other work done on the car?
