TwinTurbo.NET: Nissan 300ZX forum - Not sure if this will help but locate the purge valve
Subject Not sure if this will help but locate the purge valve
Posted by jzack on November 30, 2016 at 8:45 AM
  This message has been viewed 285 times.
In Reply To Help with 1996 300zx TT posted by zx1988 on November 29, 2016 at 07:45 PM
Message electrical connector. Since the valve is missing, the connector should be just hanging. Temporarily insert a 6.8k ohm 1/4 watt resistor across the the connectors contacts. Should be able to tape up the connector that way. Reset the ECU and see if the code stays clears?
Resistor tricks the ECU into thinking the valve is still connected.
