TwinTurbo.NET: Nissan 300ZX forum - Re: Loss of power and several other questions about z32.
Subject Re: Loss of power and several other questions about z32.
Posted by Smokiedabear on November 28, 2016 at 5:06 PM
  This message has been viewed 360 times.
In Reply To Loss of power and several other questions about z32. posted by Suupi on November 28, 2016 at 11:33 AM
Message check resistance on injectors. make sure between 10-13ohm
check spark plugs
when was last tuneup? fuel filter etc. a clogged one could cause pump to overwork and whine.
replace both 02 sensors, why not. soak in pb blaster before removal, cut wire coming directly out of 02 sensor put big socket on it to remove, if you use a box end wrench it will probably strip the 02 sensor nut.
Then see how your car does.
