TwinTurbo.NET: Nissan 300ZX forum - Re: Per my post below, I am more than willing to bet the harness
Subject Re: Per my post below, I am more than willing to bet the harness
Posted by Smokiedabear on November 17, 2016 at 6:41 PM
  This message has been viewed 372 times.
In Reply To Per my post below, I am more than willing to bet the harness posted by MixManMash on November 17, 2016 at 06:00 PM
Message I took the runner grommet on the maf connector harness side out. Prayed the pins a little forward as suggested, they all sat flush and pushed them down a little so they would clamp better. Cleared code 12 did not fix
I can't get a reading when maf is plugged in the paper lip method must of be penetrating, with maf unplugged I do get .28 from signal wire and that does not change with revs. Or engine heat.
I think the ecu has a problem. Wish i kept my na to test. I did not have a ground on wiring harness properly hooked up on back manifold and this cooked the ptu. Tightened ground swapped ptu then car would start. I think this may have affected ecu as well that is the only idea I can think of.
Thanks for all of your help I'm going to take ecu cover off tonight and see if I see any burns
ll reuept nept aq
