TwinTurbo.NET: Nissan 300ZX forum - Recent installs?
Subject Recent installs?
Posted by -Grimm- on November 16, 2016 at 5:41 PM
  This message has been viewed 341 times.
In Reply To Nismo Fuel Regulator gauge shows 0 PSI on startup posted by NitroPow on November 16, 2016 at 12:29 PM
Message You don't mention if you just added all the fuel system upgrades or if it was running fine prior to adding the gauge.
Either way, your wording leads me to believe you may have installed the fuel pressure gauge in the wrong spot, or plumbed the fuel system incorrectly.
The regulator maintains upstream pressure by bleeding off excess. Therefore, your plumbing should be:
Pump
Filter
Pulse Dampener (if installed)
Gauge
Fuel Rail
Pressure Regulator
Return to tank
If it is plumbed how it sounds (Pump, filter, FPR, Gauge, fuel rail, return) then you are not getting fuel pressure to your injectors.
Black smoke is excess fuel. If you just installed the injectors perhaps pinched injector oring is leaking fuel into some cylinders?
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Stock Turbos) (Est. 400 HP)
1990 300ZX TT 5 Sp (GT600R) (Est. 600 HP)
2004 G35 Sport 6MT (DD)
2008 Honda Civic (DD)
2014 Nissan Murano (DD)
1969 Chevy C10 (Toy)
1969 Chevelle (Toy)
