TwinTurbo.NET: Nissan 300ZX forum - Code 12? Tried 2 Mafs and different TPS
Subject Code 12? Tried 2 Mafs and different TPS
Posted by Smokiedabear on November 16, 2016 at 2:27 PM
  This message has been viewed 443 times.
Message The 91 TT z is pulling a code 12.
unplugging and plugging back in maf will not help, idles ok until it gets out of warm-up cycle then jumpy but stays running.
TPS has been adjusted, adjusting it either way when running does not truly affect idle but I do hear a click from it, it tests ok on mulitmeter
Maf harness has power going to it to signal wire and ground is there.
I've tried 2 mafs, harness is 1.5 years old, tt ecu
Carbon canister delete has been performed.
I have a 3rd maf on the way but not sure if that will fix.
Could it be a bad boost leak? Pretty sure I hooked these guys up nice and tight when I check I dont see any apparent leaks.
Wont rev past 2500rpm
