TwinTurbo.NET: Nissan 300ZX forum - Recommend getting a clip.
Subject Recommend getting a clip.
Posted by upcominZ_(NOLA) on November 14, 2016 at 12:46 AM
  This message has been viewed 366 times.
In Reply To NA to TT and AUTO to Stick Conversion, different scenario posted by dancefloor on November 13, 2016 at 04:53 AM
Message I just did this, tt swap and 5spd at the same time. On the 5spd swap, use the one piece ss hose for clutch line. The ps and ac lines are all different. Ac condenser and rad are different. Get an aftermarket oil cooler and intercoolers. Going to need turbo piping, couples, and bovs. R1 has a bracket to make the tt rad use the na mounting points. You need the clutch pedal and cut the auto brake pedal. Use the auto harness and splice in the reverse lights, they are 2 green wires.
Clutch' flywheel, and slave. Also an na clutch master cylinder. Finding all the bolts for everything will be hard. U need a tt fuel pump or a 255 walbro.
===================================Sig==============================
'You know how an SUV sits just high enough to a Z that their damn headlights blind the shit out of you? Well on an H2 it’s almost like the movies when the person is being abducted by aliens.' james-lee
"I'd rather stroke it. (n/m) - Ash's Z 22:45:31 10/30/06"
