TwinTurbo.NET: Nissan 300ZX forum - Should the CAS be hot to the touch?
Subject Should the CAS be hot to the touch?
Posted by NNayak on November 12, 2016 at 8:43 PM
  This message has been viewed 321 times.
Message Hello,
I just swapped an old-style CAS to a used new-style CAS while troubleshooting a problem on my 94 NA-->TT in which the car, once hot, idles roughly and experiences commanded (ECUTalk readout) idle timing fluctuations between 15* and 30+*BTDC.
After idling the car up to temp, I shut the car down to perform some other work. When I went to hot restart the car, I couldn't get it to fire up.
I did note while under the hood that the CAS housing was quite hot to the touch. I can't remember if the old-style unit that I removed from the vehicle would become hot in operation. Is this normal, or is the used new-style CAS suspect?
Thanks!
