TwinTurbo.NET: Nissan 300ZX forum - Below 30 doubt if wheel balance is an issue, Check >>
Subject Below 30 doubt if wheel balance is an issue, Check >>
Posted by ZUL8TR on November 12, 2016 at 4:00 AM
  This message has been viewed 219 times.
In Reply To Hit a pothole on the highway last night,now have a wobble posted by aquariuscsm on November 07, 2016 at 09:33 AM
Message the strut from frame to suspension for damage. If the strut is old might have popped the seal on the silicone and that allowed more slack in the joint?
Look for a damaged rim for out of round or lateral dent at tire bead.
Also possible is you broke the tire belt(s) internally. Not easy to determine that but look for local area damaged rubber on the tread. If you see damage or not replace the tire with one from the rear (NA all tires the same but use same side since the rims are directional) and see if problem goes away. I it goes away gotta get a tire :-( since once belts damaged tire is unsafe.
ZUL8TR in Orlando,FL
