TwinTurbo.NET: Nissan 300ZX forum - Re: Some thoughts
Subject Re: Some thoughts
Posted by Smokiedabear on November 11, 2016 at 1:22 PM
  This message has been viewed 301 times.
In Reply To Some thoughts posted by ThisIsSparTTa on November 11, 2016 at 09:25 AM
Message The car runs well now I had an injector not fully plugged. Now I get a code 12. Car is on a txt harness and ecu with new knock sensor, 02 sensors, ptu etc.
The car will not rev past 2400 as usual with a code 12. I have 2 Mars both were working on the na and txt car prior to swap. Now when I plug or unplug them, no change in car behavior.
The tps is from my na as the txt one was damaged and is not adjusted but I don't see why this would pull a code 12
It is almost like the man harness is not looking for the man at all when plugged or unplugged.
I have both grounds on back of intake mani near coil 3 and 6 and also the ground that runs off the mad harness I have going to the frame rail. I tried changing spots on the frame rail for this and where it sat but this did not resolve.
I disconnected and reseated ecu but this did not resolve.
I find it hard to believe both of my Mars went bad since the swap started 3 months ago but the ptu/igniter thing was bad so I used my na recall issued one and that resolved. That ptu/igniter did work prior to the swap.
Thank you for all of your help very excited to resolve and enjoy the perks of the txt swap :)
