TwinTurbo.NET: Nissan 300ZX forum - Some thoughts
Subject Some thoughts
Posted by ThisIsSparTTa on November 11, 2016 at 9:25 AM
  This message has been viewed 292 times.
In Reply To Re: NA to TT swap running kinda rough - first start posted by Smokiedabear on November 10, 2016 at 11:31 AM
Message Did you replace your ECU chip with one programmed for this engine and injectors?
Did you pull ECU codes, or just look for a light? Not all codes generate a light.
Do you have a Selin translator? Do you have it on the right setting (add/avg)?
Have you verified all of your connections are going to the right place, and you haven't done something like swap #6 with the O2 connector that's right there?
Have you verified the PTU is working correctly?
Verify fuel pressure. Verify no major boost leaks. Etc.
