TwinTurbo.NET: Nissan 300ZX forum - auto to 5spd wiring issues
Subject auto to 5spd wiring issues
Posted by upcominZ_(NOLA) on November 05, 2016 at 11:40 PM
  This message has been viewed 357 times.
Message Its been a while, but finally got around to fixing the z. I bought a 93 convertible z and did the tt swap and 5spd swap. Everything has worked out except for the wiring harness. I don't have an auto transmission harness, only the 5spd harness. The body harness and the 5spd harness don't match. I know how to get the reverse lights to work, and the starter relay switch, but don't know what to do with this plug.
I looked over the ECCS wiring diagram in faq, and see the pins for the speed sensor and neutral switch. I just don't get what the wires are for in the middle. Im thinking one pair will the oil pressure switch and the other pair the volt meter.
I have the 8 pin connector from the 91' 5spd on the body side that I removed from the donor, I would like to de-pin it and slip in the 5 pins from the auto body harness and the 2 from the reverse lights to have the 7 pins. Any suggestions?
The body harness connector is in the background and the 5spd harness is in my hand. 5 pins and 7pins.
===================================Sig==============================
'You know how an SUV sits just high enough to a Z that their damn headlights blind the shit out of you? Well on an H2 it’s almost like the movies when the person is being abducted by aliens.' james-lee
"I'd rather stroke it. (n/m) - Ash's Z 22:45:31 10/30/06"
