TwinTurbo.NET: Nissan 300ZX forum - Turn signal housing removal (with stripped bottom screw)?
Subject Turn signal housing removal (with stripped bottom screw)?
Posted by mysticLegoZ on October 29, 2016 at 10:51 AM
  This message has been viewed 329 times.
Message Q: Regarding the driver's side front turn signal housing: If the bottom screw is stripped (spinning without any forward/backward movement) and the top screw is fully removed, is there any recommended process for removing the housing?
I am a bit wary of prying at the housing. Potential damage including the plastic/lens (which seems brittle), surrounding paint, and any unknown effects of pulling with the screw in place.
The end goal is to replace the bulb.
Any ideas/recommendations will be appreciated.
Thanks
