TwinTurbo.NET: Nissan 300ZX forum - Might be the coolant flow valve for the core. Of course
Subject Might be the coolant flow valve for the core. Of course
Posted by jzack on October 25, 2016 at 9:03 PM
  This message has been viewed 336 times.
In Reply To ack!! suddenly lost heat, just when its getting cold =( posted by stockplayerz(nyc) on October 25, 2016 at 11:54 AM
Message it's electrically operated and under the dash. FSM tells how to put the climate system into diagnostic mode. You can try forcing the valve fully open that way. There are posts about finding the valve, replacing the actuator motor, etc. it's also possible to manipulate the valve manual and set to maybe a 1/2 open position without tearing the dash apart (but still not fun, space is tight under there).
It's also possible the heater core is clogged but if you've done coolant flushes every 5 years or so that shouldn't be an issue.
