TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: NA->TT FPCU wiring
Subject Re: Re: Re: NA->TT FPCU wiring
Posted by Smokiedabear on October 25, 2016 at 12:56 PM
  This message has been viewed 541 times.
In Reply To Re: Re: NA->TT FPCU wiring posted by Smokiedabear on October 25, 2016 at 12:05 PM
Message Pretty sure I found the answer based on re-reading past doc.
The purple wire is present on most NA/TT body chassis harnesses.
The BLUE harness that plugs into the fuse box on the driver's feet is where the purple wire may NOT be present.
This eventually wires to #35 on your ECU.
So if you just take your #35 from ECU and wire directly to the FPCU this will resolve the problem
The wire is purple that needs to be wired on the FPCU.
This doc was helpful, I just had to re-read it all day to understand and learn about the differences in the chassis, guess I am slow.
Here is the doc: [ http://twinturbo.net/nissan/300zx/forums/technical/view/997416/2-speed-fuel-pump-controller-wiring-for-TT-conversions.html ]
